pressure drop in boiling flow inside heated tube |
January 12, 2023, 07:03 |
Sasan Ghomi
Rep Power: 15 |
Dear Friends,
In CFD simulation of water flow boiling inside a heated pipe using the Mixture/VOF model and the Lee submodel for vaporization/condensation, two-phase flow pressure drop is much lower than the experimental data. Various parametric studies have been performed but the underprediction of pressure drop was not solved. Does anyone have experiences in validation of two phase flow boiling pressure drop in heated pipes? Br, Sasan
Best regards, Sasan Ghomi |
Simple Box - Gravity with Pressure Outlet - Unrealistic Reverse Flow | pyccknn | FLUENT | 2 | December 1, 2021 18:31 |
Pressure drop over tube, to low | Woud | OpenFOAM Running, Solving & CFD | 5 | August 16, 2021 07:10 |
3D cylinder with baffles (solid no tube) - Calculating Pressure Drop | Famous | FLUENT | 3 | May 21, 2020 07:58 |
How do I find the pressure drop in translationally periodic wavy channel flow? | dfonseka | ANSYS | 0 | April 26, 2018 18:03 |
pressure drop and two phase problem | omaralyahia | CFX | 1 | July 16, 2015 19:01 |
