Is using Pressure based Coupled solver recommended Natural Convection problem? |
January 8, 2023, 10:09 |
Mandeep Shetty
Rep Power: 10 |
Hello why is the use of Coupled solver suggested for Natural Convection flow? For a Natural Convection flow isn't the P-V coupling always weak and it is actually the Energy-Momentum coupling that need to be taken care? If this is the case then using Fluent Coupled Solver shouldn't be helpful as only Continuity and momentum equation are solved in coupled manner and Energy is solved separately in segregated way.
January 14, 2023, 06:30 |
Mandeep Shetty
Rep Power: 10 |
Does any one have any info on this ?
couple solver, natural convection |
Pressure based coupled solver for internal supersonic flow | erkampasha | Main CFD Forum | 1 | December 7, 2022 07:07 |
How is the accuracy using VOF (pressure based solver) on supersonic flow | air_fun | Fluent Multiphase | 1 | August 25, 2021 01:59 |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 07:33 |
Pressure Based Coupled Solver | A.S. | Main CFD Forum | 1 | November 8, 2015 10:59 |
Coupled solver energy equation problem | lucioantonio | FLUENT | 0 | April 3, 2009 11:21 |
