Fatal error in one of the compute processes
Old   December 29, 2022, 01:55
Default Fatal error in one of the compute processes
xiaopang is on a distinguished road
Currently, I use clusters to submit computing tasks. The submitted files include jou files, cas files, dat files and udfs. Through testing on the Winodws platform, it can run normally. After it is submitted to the cluster, it can only be automatically terminated after 10 operations. The error shown below has occurred. By viewing the log file, the following errors are found. At present, it is preliminarily suspected that it has nothing to do with the program settings, but it may be related to the cluster configuration, but the specific problem is not clear. I hope you can provide some help.
This case file mainly uses udf program to realize the collision between bubbles and inclusions, so as to eliminate inclusions. Inclusions are injected from the surface, and the total injection quantity is about 1.5 million.
I hope you can provide some solutions.Thank you very much!
Flow time = 10.11s,time step = 10011
9 more time steps
Message from the Cortex Process
Fatal error in one of the compute processes.
Error in '/public/software/ansys_inc/v201/fluent/fluent20.1.0/lnamd64/3dp_node/fluent_mpi.20.1.0' : free():corrupted unsorted chunks:0x0000000005bd5700 ***
xiaopang is offline   Reply With Quote
error, fluent
Error When Calling F_FLUX: received a fatal signal (segmentation fault) zimao Fluent UDF and Scheme Programming 4 November 19, 2020 22:07
Specs for a compute and head nodes rhythm Hardware 3 August 14, 2020 09:55
DEFINE_ADJUST compute gas-liquid interface force, error after hook guohf Fluent UDF and Scheme Programming 3 February 29, 2020 05:31
How do I compute the normal vector to a surface with FEM Vasilis Main CFD Forum 3 July 31, 2009 08:59
Fatal error error writing to tmp No space left on device maka OpenFOAM Installation 2 April 3, 2006 09:48
