Call defined property by UDF to another UDF
Old   December 27, 2022, 09:57
Smile Call defined property by UDF to another UDF
Mohammad
Selawe97 is on a distinguished road
Hello
I am a new user of UDFs
My question is I defined a property (Saturation temperature depends on pressure) using a UDF code,
and I defined another UDF (source term UDF) which needs to include the property of the first UDF (Saturation temperature UDF), but the problem is how I can call the defined property from the first UDF(Saturation temperature UDF) and use it in the second UDF (source UDF)?
Thanks,
Mohammad
Selawe97 is offline   Reply With Quote
property udf, source code, udf code
Using parameter defined in one UDF into another UDF marijam Fluent UDF and Scheme Programming 7 November 18, 2021 09:10
Vaporization pressure UDF property problem? lehoanganh07 Fluent UDF and Scheme Programming 1 September 13, 2014 11:59
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 keepfit ParaView 60 September 18, 2013 04:23
UDF to call execute command mactros Mcgregor FLUENT 0 June 12, 2003 05:53
Routine call in UDF Christian FLUENT 0 May 21, 2002 04:49
