Rep Power: 5 ![]() |
I'm trying to perform a cooling plate analysis for a battery. The cooler channel has common surfaces with the aluminum plate(fluid solid interface). Therefore, I defined the interface surfaces in mesh and matched them in the interface section in fluent. I want to change the material of the cooling channel but leave the plate as aluminum. I tried to make a new definition using copper in Fluent database, but there was no change in the results. I think it should appear in cell-zone for me to change the material, but I don't know how to do it because the channel whose material I want to change is also fluid domain. Could you help me, please? |
#2 | |
Kareem
Rep Power: 3 ![]() |
If I understand correctly: you have a solid aluminum domain, some interface material, and then a fluid domain. If you want to change the material in between the aluminum and fluid you will have to define the interface as a coupled wall. Under options for the wall, you can select the new material, copper, and give it a wall thickness. In the heat conduction calculation it will add the layer of copper into the calculation of heat transfer from the fluid to the aluminum. Let me know if I understand your setup correctly and I can provide some more detail on how to achieve this.
Please like the answer if it helped! Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
Adding material to CFX material library | marlon | CFX | 2 | October 16, 2016 09:33 |
[DesignModeler] Assigning Materials to Geometry | ImSoDumb | ANSYS Meshing & Geometry | 0 | November 20, 2015 15:47 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
