Effect of mesh on the HTC value
Old   December 22, 2022, 17:05
Default Effect of mesh on the HTC value
Waru
modorous is on a distinguished road
I'm running a multi-phase simulation with heat transfer, where a coolant liquid is poured onto a copper surface. Coolant liquid and air are the two phases. The copper surface has a constant temperature of 130 C and liquid is poured at a temperature of 75 C. Surrounding air has a temperature of 100 c. I'm using automatic mesh adaption (AMA) defined for multi-phase VOF. I am calculating HTC using the T_ref method (Surface Heat Transfer Coef.). Since this is an external flow I am using the liquid coolant inlet temperature (80 C) as the reference temperature.
I ran three simulations for different minimum edge lengths, but the HTC values I get are very different from each other and very high compared to the experimental results. Results without AMA are somewhat closer to experimental results but still high. Since I'm looking at mesh dependence, I understand there should be some variation, but the difference in results is significant.
Is it a requirement for the fluid-solid interface surface to have a constant mesh size, is this the reason for my varied results?
Thanks,
Best regards,
Waruna
modorous is offline   Reply With Quote
adaptive mesh refinement, fluent, heat tranfer coefficient, multi phase flow, vof
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 13:38
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 18:16
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 05:17
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 07:21
