Problem with hydrogen leakage model
Old   December 20, 2022, 10:24
Question Problem with hydrogen leakage model
mehrdadmostafavi is on a distinguished road
Hello all,
I'm simulating hydrogen leakage from a pipeline to free space, with wind flow from left to right in a steady state. I have the following problems. I would be grateful if anyone could help me.
1- My Geometry is a box with an orifice in the middle of the bottom face of the box as a leakage point. (See attachment)
2 - the boundary conditions are like this:
  • Mass flow inlet for the leakage point
  • Velocity Inlet for Wind in the left face of the box
  • Pressure outlet with the option of "prevent reverse flow." for all the rest faces
  • Wall around the leakage point
I activated the species transport, K-e turbulent model, and energy equations.
Problems:
  1. I have 3 sample sizes for the leakage point and 4 for the wind speed. I did the mesh independence study for a 1mm leakage size, but the problem is that it doesn't work when I change the leakage size. I tried several mesh types, and the best one was the structured one that I'm using now with the O-grid type for the leakage orifice.
  2. Another problem is that I will have water vapor in my answers, which means that the decrease in the H2 concentration is not due to diffusion, but to the consumption of H2 to produce H2O. I want to know what the solution would be for it.
  3. When I want to consider the scenario with 0 wind flow rate, the continuity doesn't converge, even if I'll change the wind inlet as an outlet. It seems like hydrogen fills the space, which is unacceptable for free space.
I really appreciate any help you can provide.
mehrdadmostafavi is offline   Reply With Quote
fluent, hydrogen diffusion, hydrogen leakage, leakage, species transport model
Problem using Partially-Premixed Combustion > G-Equation model Daveo643 FLUENT 5 May 27, 2021 03:00
The problem of Stiff Chemistry Solver in Multiphase model shenzhou1987 FLUENT 1 January 11, 2016 03:52
Problem with k-epsilon model torkness FLUENT 2 February 27, 2015 03:44
problem in glass radiation model (DO model) wunan805 FLUENT 0 October 10, 2012 06:06
Turbulence model for mixing problem??? nileshjrane Main CFD Forum 7 September 14, 2010 05:57
