Facing problem in validation of turbulent flow |
December 20, 2022, 08:21 |
Odisha
Rep Power: 6 |
I have been trying to simulate a turbulent flow through a rectangular microchannel. I am validating a numerical paper that solved turbulent flow through a microchannel of dimensions 0.5mm x 5 mm x 20 mm. The working fluid is water at 308K. The model used is the standard k-epsilon model, as the author has used the same.
The pressure drop obtained by the author is 4.9kPa while the pressure drop I obtained is around 11 kPa. Please help me regarding this issue. The paper: Paper link Images of my setup are attachedi2.jpg Screenshot 2022-12-20 141447.jpg |
Nusselt and friction factor validation in turbulent flow | me.po | FLUENT | 7 | July 24, 2023 03:16 |
How much does the source code for this turbulent flow CFD code worth in US $? | Dr Youssef Hafez | Main CFD Forum | 43 | January 4, 2023 01:13 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Validation case for turbulent flow | Ratan | Main CFD Forum | 0 | October 4, 2005 03:03 |
turbulent flow in cavity problem using k-w model | khairy | Main CFD Forum | 3 | February 27, 2005 12:12 |
