DPM or dense discrete phase model?
Old   December 15, 2022, 15:37
Default DPM or dense discrete phase model?
curious scientist is on a distinguished road
I want to simulate the powder particles that are being injected into a chamber with hot gas flow. The volume fraction of particles is much less than the gas (definitely less than 10%, which means that I can use just the DPM).
Because there will be mass and heat transfer between powder particles and gas flow, I am not sure whether I should use just the discrete phase model alone (multiphase off), OR I should use the multiphase model and enable the dense discrete phase model.
I appreciate it if anyone could answer this question.
Thanks!
curious scientist is offline   Reply With Quote
Old   December 16, 2022, 07:03
alainislas's Avatar
Alain Islas
alainislas is on a distinguished road
The dense discrete phase model (DDPM) only accounts for the particle-particle stresses. This is generally done via the KTGF and formulation for the granular temperature. In other words, DDPM has little to do with mass and heat transfer phenomena. Only accounts for forces and kinematic features.
Certainly if your volume fraction is < 10%, DPM can do the job. The heat and mass transfer features are available. Also is computationally cheaper.
alainislas is offline   Reply With Quote
dense dpm, discrete phase
Tracking particles in discrete phase model (dpm) abolfazl FLUENT 0 November 22, 2018 10:47
UDF for tracking particles in DPM abolfazl FLUENT 1 October 27, 2018 13:32
Dense discrete phase model Theerawat FLUENT 6 April 21, 2016 17:13
DPM model w/ Wave model - errors in documentation HS FLUENT 0 April 12, 2006 05:37
Discrete Phase Model Query johnnyb FLUENT 1 March 5, 2004 13:54
