Rep Power: 3 ![]() |
Hello everyone,
I'm modelling two fluid zones, one consisting of O2 & N2, the other consists of H2 and H2O, the two fluid regions are separated by a solid body, so each fluid zone has a solid wall boundary as a neighbour. On the O2 side I would like to apply an O2 sink on the wall, so that the wall absorbs a specific amount (kg/s) of O2 from my fluid zone 1. On the H2 side I would like to apply an H2 sink on the neibouring solid wall and on the same wall I would like to apply an H2O source into my fluid zone 2. If I understand correctly I have three options to model my problem: A) Use species transport + surface chemistry on wall (not a perfect option as I do not wish to acutally model the chemistry reactions) B) use UDS and a UDF_DEFINE_FLUX macro C) Model a very thin volume sink close to the wall If I'm misssing another option please let me know! I think option B) would be the most accurate and elegant way to model my problem, however I have no experience using Define_flux UDFs and I would like to know: Is it possible to use such a udf and only sink/ source one species into my fluid zone from the wall? I do know how much kg/s or mol/s I want to sink/ source into my fluid. Or can you give me ideas for modelling such a problem, if I'm missing out of other Fluent capabilities? Thanks in advance, Helen |
fluent - udf, sink term, species flux |
Illegal cell label -1, fluent3DMeshToFoam | BenGher | OpenFOAM | 7 | October 10, 2023 00:02 |
Wall shear stress for solid phase? | qi.yang@polimi.it | OpenFOAM Programming & Development | 0 | February 24, 2020 06:26 |
[solids4Foam] How to calculate drag coeff when using solids4Foam | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 15 | November 7, 2019 12:50 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
