Setting radiation properties of a glass panel into DO model |
December 10, 2022, 14:54 |
Peter Maroul
Rep Power: 8 |
Hi all.
In a problem with the presence of the radiation , there is a glass panel. Some radiation properties of this glass are presented as follows : Reflectivity= 0.1 and transmittivity = .79. Also with regarding some references , glass emissivity is equal to 0.9 for this glass. Given these quantities and this fact that emissivity and absorptivity coefficients are not same , how user should set the radiation properties of this glass sheet in DO model? Thanks for any help and advice. |
absorptivity, emissivity, glass radiation proprties, radiation do model |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
How to model radiation through a double glazing window in COMSOL 6.0? | Saketh Bharadwaj | COMSOL | 0 | September 19, 2022 11:37 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
