naji
Rep Power: 3 ![]() |
Hi guys
I'm doing a time independence study i have 4 time steps and i did the simulation and defined a report definition for the parameter but after ending the simulation i realized that reports weren't saved,is there any other way to compare the results except plotting based on time for time study? i have no data to compare(except case and data of every simulation) and solution time is a lot ![]() if anyone has an idea i would appreciate |
Nilotpal Dhar
How are you defining the parameter? In the controlDict as functions?
#3 | |
Kareem
For example, assuming you are looking at an airfoil and your chosen parameter is the drag coefficient. You can determine the ending coefficient from each simulation and compare them against each other. By comparison I mean looking at the relative percent change between each mesh. Once the change is below 1%-5% (depending on you simulation, tolerance, etc.) you should be independent. If, however, the simulation is transient (moving wall, changing boundary condition, etc.) your critical parameter will likely not be a single number, but a transient plot or profile. In this case there's unfortunately no way to recover the transient data if you did not export it. If you can provide more detail on your problem I can help you determine an adequate parameter to investigate.
Please like the answer if it helped! Video Tutorials and Tips: https://www.youtube.com/@cfdkareem/featured |
time study, transient |
bash script for pseudo-parallel usage of reconstructPar | kwardle | OpenFOAM Post-Processing | 42 | May 7, 2024 23:17 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 05:49 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
Star cd es-ice solver error | ernarasimman | STAR-CD | 2 | September 12, 2014 00:01 |
plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 07:56 |
