Outlet total pressure greater than inlet total pressure |
November 30, 2022, 12:33 |
Raju Bhatia
I am getting confused with the results I am getting from one of the air duct simulations I recently did. It seems, the outlet total pressure is less than that of the inlet total pressure. |
December 2, 2022, 19:47 |
Kareem
Rep Power: 3 |
Can you add some context to your setup? What does the geometry look like, what are the boundary conditions, etc?
December 5, 2022, 00:20 |
HECKMANN Frédéric
Rep Power: 17 |
The total pressure can decrease if there are any energy dissipation. If you enable turbulent flows, it will decrease as small eddies are dissipated into heat.
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Reversed flow using pressure inlet and outlet? | here_for_help | FLUENT | 0 | September 28, 2018 15:20 |
Adjuting oulet pressure till inlet pressure reaches a certain value in timestep | pvpnrao | OpenFOAM Running, Solving & CFD | 2 | September 11, 2018 10:14 |
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions | Vishnu_bharathi | CFX | 12 | November 21, 2017 06:56 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
