what's the error in fluent pipe flow simulation
Old   November 29, 2022, 20:19
Default what's the error in fluent pipe flow simulation
MANU P ANAND
manupanand is on a distinguished road
I am currently doing an incompressible pipe flow simulation with an extended domain at the inlet. I am attaching the simulation boundary condition etc. in figure.
My question is why my simulation has a low pressure than the inlet given property, I had given 101325pa at inlet , operating pressure 0Pa.
manupanand is offline   Reply With Quote
Old   November 30, 2022, 06:30
Yogesh
yogesh03y is on a distinguished road
Pipe flow will cause a pressure loss. Look up the Bernoulli's equation, Darcy-Weisbach equation and the Goldstein equation to understand it better. A negative pressure only means that the pressure is lower than the operating pressure. You have a really high mass flow rate at inlet. So pressure loss would be high as well.
A better way to define your BC would be to give the operating pressure as 101325 Pa and define a gauge pressure value at outlet, along with the mass flow rate inlet.
yogesh03y is offline   Reply With Quote
fluent, pipe flow
Error in mass flow rates in inlet region of pipe during pipe flow simulation fluent_user121 CFX 1 September 22, 2019 15:04
Tutorial 12. Cold Flow Simulation Inside an SI Engine. Fluent 6.2 hesham FLUENT 0 February 13, 2016 09:24
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
FLUENT LES Simulation of flow past a cube NGH FLUENT 6 November 14, 2012 00:45
