November 26, 2022, 01:12 |
Centrifugal pump: incomplete pathlines
Nopparuj Jongserechoke
Rep Power: 4 |
I am trying to get appropriate pathlines results from the centrifugal blood pump simulation where mine impeller's geometry has a washout hole at the center in which fluid is expected to go down and fill the clearance of the pump volume.
When no rotation speed is defined, the flow goes down as expected (Image 1), however, when I changed the rotation speed to 1500 RPM, there is no pathline that reaches the bottom or sometimes did not even go down in the washout hole (Image 2). Here are my boundary conditions: Inlet: Mass flow inlet (0.0875 kg/s) Outlet: Pressure outlet (0 Torr) Blade: 1500 RPM Any ideas about what the causes are and how to resolve them, please let me know. |
November 28, 2022, 02:01 |
Alexander
Rep Power: 34 |
play with visualization settings
best regards ****************************** press LIKE if this message was helpful |
centrifugal blood pump |
How to find centrifugal pump CAD geometry with experimental results for benchmarking? | jgross | Main CFD Forum | 1 | October 18, 2021 13:47 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
centrifugal pump | Chalghoum | CFX | 18 | April 16, 2014 07:37 |
Autoblade centrifugal pump template | mahdi balali | Fidelity CFD | 3 | February 18, 2014 09:56 |
Centrifugal Pump Cavitation problem or not. | ismael.s | CFX | 13 | February 27, 2012 09:00 |
