November 25, 2022, 10:05 |
How do i impose the outlet mass flow rate?
Andrea Vinci
Rep Power: 4 |
I have a quick question. If the flow rate at the output of my system is known, how do I impose it? Do i have to use the target mass flow rate in the outlet boundary condition and put the mass flow rate value? And also, if I assign a mass flow inlet why do I get velocity 0 at the inlet?
P.S. I'm using fluent and I'm working on a hvac of a room. Pictures of the geometry are attached to the thread to better explain what I'm doing. Thanks in advance |
November 28, 2022, 20:29 |
#2 | |
Alexander
Rep Power: 34 |
velocity can't be 0 at inlet in cas you've set mass flow rate and pressure, you may see the velocity in initialization tab if you select initialize from inlet
best regards ****************************** press LIKE if this message was helpful |
November 29, 2022, 04:00 |
Lorenzo Galieti
Rep Power: 12 |
There’s a mass flow outlet boundary condition.
If you use it, then impose a pressure at the inlet |
November 29, 2022, 05:01 |
Andrea Vinci
Rep Power: 4 |
November 29, 2022, 05:15 |
Andrea Vinci
Rep Power: 4 |
So I have to put the target mass flow rate in the outlet bc (which is a pressure outlet) but I must have a velocity inlet. Is that correct?
November 29, 2022, 16:00 |
Lorenzo Galieti
Rep Power: 12 |
No, there's a mass flow rate Boundary condition type. No target mass flow rate. Now you have a pressure outlet, but you can select mass flow outlet option.
November 30, 2022, 04:51 |
Andrea Vinci
Rep Power: 4 |
Ok, and what type of inlet do I need to use if I have mass flow outlets? Velocity inlet? Pressure inlet? Mass flow inlet?
November 30, 2022, 07:34 |
Lorenzo Galieti
Rep Power: 12 |
Well, somewhere you will need to specify a pressure, don't you think so?
November 30, 2022, 07:35 |
#9 |
Andrea Vinci
Rep Power: 4 |
November 30, 2022, 07:37 |
#10 |
Lorenzo Galieti
Rep Power: 12 |
Seems a bit weird that you do not know the pressure of your sistem. Is this incompressible flow?
November 30, 2022, 07:41 |
#11 |
Andrea Vinci
Rep Power: 4 |
I know the mass flow rate at the inlet and I can easily calculate the velocity because I know the inlet area. The pressure at the inlet I guess is the same as the atmosphere pressure
November 30, 2022, 07:43 |
#12 |
Lorenzo Galieti
Rep Power: 12 |
Ok then impose that pressure at the inlet, and a mass flow at the outlet. Or if you know the pressure at the outlet, you can impose the mass flow at inlet and pressure at outlet.
Somewhere you need to specify a pressure, or your problem doesn't know what is the pressure, so it is ill posed. |
November 30, 2022, 07:46 |
#13 | |
Andrea Vinci
Rep Power: 4 |
mass flow inlet and pressure outlet with target mass flow rate | Zigainer | FLUENT | 13 | October 26, 2018 06:58 |
Mass flow rate boundary condition with negative values | hebe2u. | CFX | 1 | December 27, 2016 04:53 |
Compressible flow, no data at the outlet | mireis | FLUENT | 6 | September 3, 2015 03:10 |
mass flow rate... | sanjar | OpenFOAM Running, Solving & CFD | 1 | December 2, 2013 01:09 |
How Other Conditions Impact Mass Flow Rate Outlet | andy P. | Main CFD Forum | 2 | February 9, 2007 11:41 |
