How to calculate NOX values in CFD-Post or Fluent in units of ppmv on a DRY BASIS, th
Old   November 23, 2022, 13:28
Default How to calculate NOX values in CFD-Post or Fluent in units of ppmv on a DRY BASIS, th
Yarne Schlosser
Yarne is on a distinguished road
In a Fluent simulation I would like to check the number of NOx particles in parts per million volume dry (ppmvd). Does somebody know what type of expression I can use to calculate this?
Yarne is offline   Reply With Quote
Old   November 23, 2022, 15:16
Lucky
Fluent gives you the mass fraction but sometimes you can select the mole fraction as well. Convert these to ppm using the molecular weights and then convert that to the corrected dry conditions using the correction.
You can do it in Fluent/CFD post by defining custom fields or externally.
Or are you asking for an example calculation by hand to convert wet to dry values and/or corrected NOx?
LuckyTran is online now   Reply With Quote
Old   November 23, 2022, 15:36
Yarne Schlosser
I know you can get the mass and mole fractions out of Fluent.
I am more interested in how you can calculate the ppmv of dry NOx.
I found a formula for ppmd NOx, but this is parts per million (mole) and I need parts per million (volume).
Old   November 23, 2022, 15:42
Lucky
Mole ratios and volume fractions are the same thing due to Avogadro's law unless we are talking about subatomic particles, but NOx are molecules. The only difference is if you know how to move the decimal point over enough spaces.
Old   November 23, 2022, 15:47
Yarne Schlosser
I have used this formula to calculate the ppmd NOx
NO.Mole Fraction* 10^6 /(1 – H2O.Mole Fraction)
Is this formula thus also equal to ppvd NOx? Since you say that mole ratios and volume fractions are equal to each other?
Transfer Yplus values from Fluent to cfd post karachun FLUENT 1 June 7, 2020 11:14
The fluent stopped and errors with "Emergency: received SIGHUP signal" yuyuxuan FLUENT 0 December 3, 2013 23:56
CFD Post: Difference between calculated surface values using different methods Shawn_A CFX 11 July 30, 2013 14:07
Creating Face in CFD Post and export Values as Boundary Conditions flow87 CFX 2 June 4, 2011 05:06
how to calculate fuel nox in fluent ssj FLUENT 6 May 9, 2007 05:52
