Coupling of two fluent simulations
Old   November 22, 2022, 09:05
Default Coupling of two fluent simulations
Yogesh
yogesh03y is on a distinguished road
Hello everyone,
Is there a possibility in Ansys to couple two transient Fluent simulations together?
My problem involves two fluid zones.
- one where no mass flow occurs but it changes phase from liquid to solid as it discharges heat
- one with pipe flow
The flow solution of the fluid zone with phase change affects the solution of pipe flow. If I solve the two zones as two individual problems, I am getting good results. Can report definitions be exchanged between two Fluent instances at each time step?
On another forum, someone mentioned it's possible but did not explain how. Has anyone done it before?
Thanks so much!
yogesh03y is offline   Reply With Quote
Old   November 23, 2022, 00:34
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
if you got good results, why are you trying to make your life complicated?
I don't know any specific software or method.
For v22 you may run fluent using python script and organize information exchange inside script
for older verios you may use matlab (for instance) and run fluent as server (fluent aas)
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 23, 2022, 12:34
Yogesh
Hi Alexander,
Thanks for the reply!
By good results, I meant that the solution looked physical but the problem I wish to simulate needs them to work together. I wish I could just define a constant heat flux as BC in two separate simulations, but that's not the objective. The heat flux from the fluid zone with phase change is dependent on the mass flow rate in the pipe flow zone. And similarly the flow in the pipe is affected by the heat flux from the other fluid zone (temperature dependent fluid properties).
I still think my definition of the problem could be the problem. Here's another thread I posted about this model.
Transient heat discharge from Phase change material : Solution strategies
Please let me know if you think there's a better way to do this.
Old   November 25, 2022, 17:25
M Shaaban
wildemam is on a distinguished road
I am trying to do something similar between two moving bodies. I did not get to this part yet but my plan is to write a udf to exchange information between wall conditions in the same simulation with two independent zones being calculated.
wildemam is offline   Reply With Quote
coupling fluent, two fluid model, two fluid zones
how to run fluent from matlab without using aas toolbox? artemis96 ANSYS 7 May 23, 2022 13:16
Hardware for CFD simulations in FLUENT Kerouac Hardware 13 February 26, 2021 08:41
ANSYS Fluent and Maxwell suite coupling princekar Electromagnetics 0 August 10, 2017 09:03
Comparing ANSYS FLUENT and Matlab for flow simulations serguei Main CFD Forum 1 July 14, 2017 10:01
Coupling Fluent with a FEM Code via MpCCI Carsten Dehning FLUENT 0 October 27, 2002 11:41
