Periodic boundary conditions using Fluent Meshing
Old   November 21, 2022, 10:24
Question Periodic boundary conditions using Fluent Meshing
Alice
Alice_1994 is on a distinguished road
Hi, everyone.
I am doing a meandering open-channel simulation using VOF and RSM.
This meandering channel has four wavelengths, since it has the same geometry for each wavelength, I chose to only model one wavelength and set the streamwise inlet and outlet for periodic boundary conditions.
But there is a problem came across when I was trying to set the periodic boundary conditions in Fluent meshing. The error message said 'Cannot find a face zone matched with flow-inlet using the shift: ( 680.00 0.00 0.00 ). Try non-auto methods and/or adjust these parameters.' However, when I tried manually picking the periodic and reference surface, it still got the same error message.
Here are the boundary conditions I used:
1) flow inlet: mass flow inlet
2) flow outlet: pressure outlet
3) top outlet: pressure outlet
4) other: walls
I have tried many ways but am still not sure what caused this. However, when I tried to set the side walls for periodic boundaries, it worked. My guess is that in Fluent meshing, the inlet and outlet boundary could not be set as periodic boundary conditions, is that right? Then should I use another meshing software to achieve an identical mesh at the inlet and the outlet?
Many thanks for the help~
Alice_1994 is offline   Reply With Quote
Centrifugal fan j0hnny CFX 13 October 1, 2019 14:55
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Symmetry and Periodic boundary conditions CFD_Fluent_User FLUENT 1 October 16, 2014 03:18
Radiation interface hinca CFX 15 January 26, 2014 18:11
