Make perforated twisted tapes inserts
Old   November 18, 2022, 07:18
Question Make perforated twisted tapes inserts
cfd
cfd_sci is on a distinguished road
I am going to use Ansys Fluent to do the CFD analysis on 2 different geometries to investigate heat transfer enhancement features like Nusselt number, Friction factor, and Eta: both geometries are a tube with double perforated twisted tape inserts. The difference is the type of hole(one is circle and the other is rectangle). Based on the videos I have found, I know how to make a twisted tape insert in a tube. My questions are:
how to make the holes on the created twisted tape insert based on the following images?(Is it possible to make multiple holes on a rectangular plate then twist it? If yes, how?)
what kind of mesh and also method do you suggest to mesh these thin(around 3mm thickness) inserts?
Thanks for your time and consideration
cfd_sci is offline   Reply With Quote
Old   February 1, 2024, 04:05
hyugakojiro999 is on a distinguished road
Hi, I think you can find what you are looking for in this review.
https://www.sciencedirect.com/scienc...5527012030386X
You can also read the comparison of perforated TTs with other types of TTs in that study.
hyugakojiro999 is offline   Reply With Quote
cfd, cfd analysis, perforated sheet, twisted geometry
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 05:26
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 03:36
Compiling OpenFOAM13 on AMD64 with OpenSUSE 101 silent_missile OpenFOAM Installation 5 August 10, 2007 08:31
a way to make lots of money quick and easy no lies Dob Main CFD Forum 0 October 10, 2006 17:45
FOAM installation error gcc amp g hanks OpenFOAM Installation 9 January 26, 2006 15:14
