UDF to change angular velocity after every timestep based on the previous value
Old   November 8, 2022, 12:13
Default UDF to change angular velocity after every timestep based on the previous value
usr0830 is on a distinguished road
I am trying to run a simulation where the angular velocity of a dynamic mesh zone changes every time step based on this equation of motion where moment_z is the moment on the two aerofoils defined as one wall.
omega_prev + = ((1/I) * (moment_z - (alpha * omega_prev)))
When I set up the dynamic mesh with the udf, the initialisation returns an "All compute processes received SIGFPE." error. I am not sure what the cause of this error is. Could someone more knowledgeable please help me solve this?
This is the UDF I am using:
#include "udf.h"
real current_dt;
real omega_old;
real omega_new;
real moment_z;
static I = 0.0275; /* Moment of inertia */
static alpha = 0.00626;
static real omega_prev = 0.0;
DEFINE_CG_MOTION (rotational_motion1, dt, vel, omega, time, dtime)
#if !RP_HOST
current_dt = RP_Get_Integer("time-step");
if (current_dt ==1)
omega_prev = -128;
else
omega_prev = omega[2];
Message("Omega_old1 is %g",omega_prev);
Domain *d =Get_Domain(1);
Thread *t_object = Lookup_Thread(d, 2);
real moment [ND_ND], cg[ND_ND], force [ND_ND];
Compute_Force_And_Moment(d, t_object, cg, force, moment, TRUE);
moment_z= moment [2];
/* Equation of motion */
omega_prev += ((1/I) * (moment_z - (alpha * omega_prev)));
Message("Omega_new1 is %g",omega_prev);
omega[2] = omega_prev;
#endif
Thank you!
usr0830 is offline   Reply With Quote
rotating domain, udf
udf for one dimensional linear motion based on force maccheese Fluent UDF and Scheme Programming 2 September 1, 2019 03:18
UDF comilation error. urgent help please m zubair Fluent UDF and Scheme Programming 4 February 10, 2019 12:19
Fluent do not use my velocity field(by UDF) to solve energy equation tangleiplus Fluent UDF and Scheme Programming 6 January 21, 2019 22:28
adapt viscous resistance based on velocity / UDF Häwimeddel FLUENT 2 April 20, 2009 11:08
UDF velocity and temperature Raj FLUENT 3 February 1, 2009 19:29
