Wall/Wall Shadow and Interfaces
Old   November 3, 2022, 22:46
Default Wall/Wall Shadow and Interfaces
sa
oleronie is on a distinguished road
Hello, I'm a bit confuse regarding the wall/wall-shadow and interface at the same time. I want to follow the Boundary Condition.png but they have both wall/wall-shadow
At Geometry I put the mode, as "Form New Part". If my understanding is correct, this should make all the parts in the model to automatically contact each other like a share topology.
But at Meshing I need to make wall-e (fluid to fluid surface) so wall and wall shadow is form. But there is also some part I need to make as interface (fluid-fluid surface). If I put as in Name Selection.png, I need to Mesh Interface at Setup Fluent but I cannot do that.
Any solution to my problem? Can you understand what I'm trying to say?
oleronie is offline   Reply With Quote
geometry
How to identify respective wall and wall shadow in fluent from the mesh interface vipulramk FLUENT 2 February 8, 2018 07:28
S2S Radiation Model at non conformal interfaces ataoulalim FLUENT 4 May 31, 2017 14:38
[ICEM] Shadow walls in Fluent. ICEM meshes vs Workbench aarvay ANSYS Meshing & Geometry 11 January 12, 2017 13:51
Dynamic Meshing - Interfaces do not stay together Noblek330 FLUENT 1 September 18, 2014 13:32
How to set the wall condition with shadow? ryanmoser FLUENT 10 April 26, 2012 00:54
