Mass flow boundary condition for a axis symmetric diffuser
Old   October 31, 2022, 08:30
Default Mass flow boundary condition for a axis symmetric diffuser
shariq
shariq12 is on a distinguished road
Iam simulating a symmetrical 3d diffuser for the following boundary conditions:
Inlet: velocity inle: 35m/s
Outlet : Gauge pressure : 0
Engine outlet: Mass flow outlet: 30kg/s
remaining are set to be engine walls as shown in the figure 1
However doing this causes no total pressure drop within the diffuser due to the walls (as shown in the attached image), the total pressure drops on the outter walls but for some reason it does not drop on the inner walls of the diffuser.
If I run the same but change my engine mass flow outlet to pressure outlet and adjust to a negative gauge pressure iam able to see the effect of drop of total pressure on inner walls of the diffuser.
Can someone help me out, I want to maintain a constant mass flow of 30kg/s at diffuser exit with inlet velocity at 30m/s.
Please do correct me if im wrong somewhere.
shariq12 is offline   Reply With Quote
boundary condition, diffuser, fluent
Wind tunnel flow simulation boundary condition issue charan3007 SU2 0 October 21, 2021 09:27
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
