In LES model, outlet temperature is different from the enthalpy balance.
Old   October 25, 2022, 02:51
Default In LES model, outlet temperature is different from the enthalpy balance.
ljw
LEEJUWON
ljw is on a distinguished road
Hello everyone.
I am simulating flow inside a pipe.
The boundary condition is that at a pressure of 22.2 MPa, 390°C supercritical water flows in at 55 kg/h from the first inlet and 20°C water enters at 79 kg/h at the second inlet.
Is there any heat energy lost in the LES model?
In the k-epsilon transient model, it is consistent with the temperature calculated by the enthalpy balance.
When I simulate with the LES model, the result is slightly lower than that temperature.
Could you help or guide me in this matter?
ljw is offline   Reply With Quote
boundary condition, enthalpy balance, outlet temperature, temperatrue
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
VOF model + mixture model + RAS or LES model ebtedaei OpenFOAM Running, Solving & CFD 23 May 12, 2018 04:36
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
