DOE Maximum temperature
Old   October 20, 2022, 07:31
Default DOE Maximum temperature
Giuseppe
peppebru is on a distinguished road
Hello mate,
I'm a MSc aeronautical engineer working on my thesis project and I need to set parametric study.
I set all for my input parameters, as Heat Flux and Inlet Mass Rate, and I need to set my output that should be Maximum Temperature in the fluid. However when I set it and run the parametric study my output Temperature is always the same. I tried to do it one by one and it's work, if I do with DOE doesn't work.
I suppose to do it one by one but should be more than 3k simulation and I think will spend so much time.
Could anyone help me?
Thank you so much in advance
peppebru is offline   Reply With Quote
design of experiment, doe, fluent, maximum temperature
Specifying output parameter as Maximum temperature st_vespucci FLUENT 1 January 25, 2018 16:36
Difficulty In Setting Boundary Conditions Moinul Haque CFX 4 November 25, 2014 18:30
fluid flow but temperature raises from nowhere? mxcfd STAR-CCM+ 5 September 16, 2014 06:46
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
the maximum value of granular temperature haijj FLUENT 0 August 25, 2008 06:02
