October 19, 2022, 11:16 |
Using DPM
Utrecht
I have a simpel case of air entering a vessel tangentially and leaving it at the top of it. This air is transporting particles with density 400x density of air. At the bottom there is an opening where the particles should leave the domain, but no air can leave here (mass flux 0). I gave the particles mass and use gravity. I see that the particles keep rotating in the vessel for ever, without descending down by gravity. Does anyone have an idea whats going wrong here? Thanks in advance. |
October 26, 2022, 09:32 |
Alain Islas
Rep Power: 7 |
what is your particle size? particle velocity? Do you have two way coupling enabled? Please post some images of your DPM setup and domain.
October 26, 2022, 10:38 |
Rep Power: 5 |
Particle diameter 1cm, velocity 70 m/s, no two way coupling, shape factor 0.06
October 26, 2022, 11:36 |
Alain Islas
Rep Power: 7 |
Ok, particles are very big and very very fast!. At such condtions I feel that most likely your particles adopt ballistic behavior.
1) Can you please calculate the Stokes number? 2) Also, calculate the particle settling velocity. 3) Please post images of your domain, or partilcle tracks |
October 26, 2022, 11:48 |
Rep Power: 5 |
I will, but can Fluent calculate 1 and 2? |
October 26, 2022, 12:00 |
Alain Islas
Rep Power: 7 |
No, you need to estimate them ... These numbers will give you very important information of your system! Please read the theory
divergence issue when updating dpm sources | mohamadalimirzaei1994 | Fluent Multiphase | 0 | August 17, 2020 13:53 |
Confused between DPM and multiphase flow | pchoopanya | FLUENT | 0 | June 21, 2019 05:44 |
DPM mass flow | kingpots | FLUENT | 0 | November 29, 2012 23:20 |
Dpm injection mass flow rate | diamondx | FLUENT | 0 | November 22, 2012 14:04 |
DPM injection mass flow rate | kingpots | ANSYS | 0 | November 22, 2012 12:12 |
