Real Gas Critical Properties for Averaged Mixture |
October 18, 2022, 20:19 |
Braden Kerr
I am attempting to model a real gas using the Peng-Robinson EoS. I am aware that I need critical properties for such a model, and Fluent provides many already for pure components. I have a custom "pure" component that is really an average of mixture species. I dont have access to the full species breakdown, so I am unable to use the mixture equations. Since it is a custom material, I believe I will need to use RGP tables to generate the fluid property. I have tabular data for the viscosity, conductivity and C_p based on pressure but have only found information for generation of RGP for CFX, not Fluent. Is there a guide for generating RGP tables for Fluent and not CFX? Thank you, bfkerr |
peng-robinson, real-gas, rgp |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
error: uninitialized local variable 't' used | MASOUD | Fluent UDF and Scheme Programming | 5 | October 17, 2016 04:24 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
defining a term for a domain using DEFINE_ADJUST | MASOUD | Fluent UDF and Scheme Programming | 1 | September 24, 2010 05:08 |
Real Gas Mixture With Reactions | Jake Cannon | Main CFD Forum | 0 | January 16, 2007 11:46 |
