FLUENT Solution Initialisation
Old   October 13, 2022, 23:02
Default FLUENT Solution Initialisation
Brett
Bdew8556 is on a distinguished road
Hey all,
I'm getting back into using FLUENT after years of using CFX.
I'm wondering how to initialise a simulation using a previous result/data file in the same way you can with CFX.
Any thoughts?
B
Bdew8556 is offline   Reply With Quote
Old   October 14, 2022, 06:03
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Assuming it is on a different grid (otherwise, well, it is kind of just the same case), you create an interpolation file from the original case and read it in the new case after the basic initialization
sbaffini is offline   Reply With Quote
fluent, initial conditions
What is the Y+ base heat transfer coefficient in ANSYS fluent solution ? Kmech FLUENT 3 March 20, 2023 12:20
OpenFOAM vs ANSYS Fluent (Solution and Schemes) gentodin OpenFOAM Programming & Development 2 February 21, 2021 21:56
solution convergence and mesh density in k-omega model (FLUENT) ripong FLUENT 0 January 29, 2015 18:09
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 11:54
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 03:00
