Why pressure in Fluid Cell is larger than Inlet Boundary condition?
Old   October 12, 2022, 03:57
Question Why pressure in Fluid Cell is larger than Inlet Boundary condition?
CC
qingnian is on a distinguished road
Dear all,
I have a cylinder model, The upper top surface is the pressure inlet 2500Pa, and the lower bottom surface is the pressure outlet 0Pa.
There are some particles in the container, which is used to calculated for the pressure drop in the container.
But I found that at some point, the pressure in the middle position of the container will exceed the boundary conditions set by the pressure boundary (such as larger than 2500Pa, pressure at some time is 2700Pa, some thing like that).
The Fluent DDPM model was used to do the simulation.
Can anyone explain what could be the reason for this problem, or how can i fix it?
thanks! Cheers!
qingnian is offline   Reply With Quote
ddpm, fluent, inlet and outlet pressure, pressure
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
CFX fails to calculate a diffuser pipe flow shenying0710 CFX 7 March 26, 2013 05:13
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
