low-Re-model instead of wall function
Old   October 2, 2022, 20:06
Default low-Re-model instead of wall function
Bob
BigBoBy is on a distinguished road
I would like to use the low-Re-model instead of the wall function in ANSYS Fluent. Do I have to change anything in ANSYS? Or is it enough if I define the first mesh layer with height y^+=1. Does ANSYS notice that I want to use the Low-Re model if the meshing is sufficiently fine at the wall?
BigBoBy is offline   Reply With Quote
Old   October 11, 2022, 01:02
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
select k-w turbulence model
select Low-Re corrections
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
ansys fluent, low-re rans, wall function
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
[snappyHexMesh] How to draw a 3D-Drawing for Meshing Kahnbein.Kai OpenFOAM Meshing & Mesh Conversion 4 June 15, 2021 13:16
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Wall function k-omega SST model Ema40 FLUENT 2 March 13, 2018 05:40
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 07:27
