FSI of Vibrating Channel
Old   September 27, 2022, 02:52
Default FSI of Vibrating Channel
Joseph
jseamon1 is on a distinguished road
Hello All,
I have a 2-way-coupled fsi simulation where I am trying to simulate flow through a very flexible channel (channel modulus 3600 pa) and apply a transverse vibrational displacement to the channel of about 100 hz (see pictures for explanation). The ends of this flexible channel are connected to much stiffer channels as well to simulate better what is happening in our experimental setup.
I have the simulation setup and have tried running it, but the problem is that when I introduce the transverse vibration to the tube, I get a reverse flow warning from the fluid solver which cause the elements in the solid domain to warp in a very odd way (the channel essentially collapses on itself).
I am hoping I can get some help from someone who would be able to look over my setup and perhaps help me identify what I need to adjust to get convergence. Thank you for your help!
jseamon1 is offline   Reply With Quote
ansys, fsi
LES Setup of a cyclic channel flow for compressible solver Phil910 OpenFOAM Running, Solving & CFD 3 November 14, 2024 08:42
[solids4Foam] FSI case does not converge, foam extend 4.0 MFWilliams OpenFOAM CC Toolkits for Fluid-Structure Interaction 12 May 13, 2022 09:35
Two way FSI of vibrating or oscillating Plate Sandeep Reddy FLUENT 0 May 25, 2017 17:39
one way FSI: large deflection of cantilever beam inside a microfluidic channel o_mars_2010 CFX 1 October 31, 2012 00:17
ANSYS/CFX, MFX FSI: piezoelectric microfluidic channel pumping problem gogohusky CFX 0 December 12, 2011 13:44
