fluent hex to tet interface
Old   September 21, 2022, 09:06
Default fluent hex to tet interface
torreh is on a distinguished road
hello everyone,
I am using Fluent Meshing to generate a hexcore mesh with tet transition to prism layers from a tri surface mesh. The transition from hex to tet is done by splitting each quad face into 2 tris.
After i import the mesh back into ICEM, i fix the uncovered faces which creates a part containing all quad & tri elements at the transition. I then separate those elements into 2 parts (UNCOV-QUAD & UNCOV-TRI). Both parts share their nodes and the tri part has the twice the amount of faces as the quad part.
When i load the mesh into fluent, both parts get defined as wall. I would like both to be interior. My first idea was to define both as interface. But i am unsure if this is the most efficient and accurate way of doing this.
Would a transition with pyramids be better?
In an earlier version of fluent, back when "/mesh" was called "/grid", there was a function called "/grid/make-hanging-interface", which would do exactly what i want. Does anyone know the equivalent in fluent 18.2?
thanks for your help in advance
torreh is offline   Reply With Quote
fluent, hanging nodes, hexahedral mesh, pyramids mesh, tetrahedral mesh
How to use the CFX periodic interface zhihuawan CFX 61 January 15, 2018 17:20
Question about adaptive timestepping Guille1811 CFX 25 November 12, 2017 18:38
pimpleDyMFoam - rho not found maasyraf3 OpenFOAM Running, Solving & CFD 10 June 5, 2017 14:05
Radiation interface hinca CFX 15 January 26, 2014 18:11
[Other] mergeMatchPairs with arcs vainilreb OpenFOAM Meshing & Mesh Conversion 1 August 5, 2013 09:11
