Simulating turbulent flow in pipe with heat transfer (water circulating panel) |
September 17, 2022, 16:09 |
Hi everyone
I've got three serious problems in simulating turbulent flow of water(Re=95922) in a spiral pipe installed on a water circulating panel exposed to radiation on one side. 1_ the rate of heat transfer to water is highly impprtant to me, what would be 2 of the best turbulence models for this problem? What are the required y+ and meshing settings? 2- what methods do you advise? 3- As you can see in attached photos the residuals especially continuity residuals don't get converged. Do I have to continue until continuity residual is below 1e-6 or if it say reaches 1e-3 or 1e-4 and stays consistent is sufficient? How do I reduce the residuals? I would appreciate it greatly if someone who knows the answers would help me... |
Solver for an incompressible, turbulent flow with heat transfer | tH3f0rC3 | OpenFOAM Running, Solving & CFD | 9 | June 17, 2019 06:12 |
Flow around heatsink with heat transfer | S Mughal | FLUENT | 0 | April 13, 2018 13:06 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Flow around pipes - heat transfer coefficient on the wall of pipe | doodek | Main CFD Forum | 2 | November 23, 2009 08:48 |
Heat transfer coefficent in turbulent flow | Ola Lindgren | Main CFD Forum | 2 | November 17, 1998 05:49 |
