Weird temperature at the outer wall in combustion chamber
Old   September 15, 2022, 07:59
Default Weird temperature at the outer wall in combustion chamber
Michał Basisty
omichalo121 is on a distinguished road
Hello, I'm trying to simulate a combustion in a combustion furnace. Whether i have a good temperature inside of it or not, the problem is that there is a weirdly high temperature ath the outer wall. The inner wall has the temperature of combustion chamber, then when the conduction comes in, the temperature inside of the wall goes to around 320 K just to change itself to around 600 K at the outer wall. Posting some images to get some visualization of it (temperature surface and the settings for outer walls)
The chamber also consists of 2 layers of different bricks - and the same problem appears and the connection of the bricks.
I have almost the same setting for the floor, the difference is the HTC at 5 and different material.
Do you have any idea what's wrong with it?
omichalo121 is offline   Reply With Quote
Old   September 16, 2022, 01:33
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
turn off "node values" option while making contours
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   September 16, 2022, 02:13
Lucky
Looks like you are removing some sort of heat flux from between the two wall layers so that the heat is coming in from both sides, the outer wall and inner wall. Are you applying this convection boundary condition inside?
Old   September 17, 2022, 06:00
Michał Basisty
I didn't put any bc between these walls other that making there a shadow wall. But if that was the case, why would it happen on the side walls when there is only one type of wall?
Thank you all for the responses.
Old   September 17, 2022, 08:07
Lucky
I need to confirm the thermal condition of your wall and shadow wall pair are BOTH coupled? If either of them are not, then that is your problem. Because you are showing a pic of a convection BC condition, which I hope is being applied somewhere else. Can you draw a cartoon of each surface layer and type of BC being applied? Alternatively you can just post the 5 screenshots of each BC.
Old   September 19, 2022, 05:21
Michał Basisty
Hi, here is some BC of the walls and floor for you to check. Hope they're bad so we might find the problem.
combustion, convection
Wall Temperature in Nozzle with RhoCentralFoam Hillie OpenFOAM Running, Solving & CFD 1 August 25, 2024 09:03
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
a sinusoidal force added to the wall of combustion chamber zhichaozhao FLUENT 1 August 24, 2016 09:09
Free stream temperature in tube wall saharesobh FLUENT 2 November 19, 2012 08:32
