Lower heat-flux near symmetry condition on surface |
September 14, 2022, 10:44 |
Jannis
Rep Power: 4 |
Hello everyone,
I'm currently doing heat-transfer calculations on an rocket engine. For that purpose I've created a model representing a section of that engine, that can be seen in the picture. On each side of the model a symmetry condition is established. The wall has a constant thermal boundary condition with a temperature set to 700K. I've noticed that the heat-flux is not constant in circumferential direction as it should be, but rather has a maximum in the middle and lower values at the sides (near the symmetry borders). I've checked the flow properties (like velocity, pressure and temperature) but they're all constant in circumferential direction, as I'm not modelling combustion but rather a hot gas flow (in that specific case it's actually just hot air). Now I'm wondering if anybody has an explanation or has encountered the same problem. Any help is much appreciated. Thanks a lot Jannis fluid_region.png heatflux.png |
Total heat transf. rate vs Total surface heat flux | Renato Sousa | FLUENT | 1 | April 14, 2020 04:27 |
Heat flux Boundary condition | cfd_worker99 | FLUENT | 2 | April 3, 2018 20:23 |
Total Surface Heat Flux | cfmyd | FLUENT | 0 | June 27, 2014 17:00 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
monitoring dynamic heat flux through a surface | abdnakhi | FLUENT | 0 | August 15, 2005 10:57 |
