how to calculate the heat flux/flow inside a solid block |
Tongyu Wang
Rep Power: 0 ![]() |
Hi all,
I'm simulating a multiphase boiling model with conjugate heat transfer with a block of solid material cooling in water. After running the simulation, I noticed that the heat flux at solid surface is much smaller than my calculation based on experimental data. Therefore, I wanted to check the heat flux/flow at a certain position inside the solid domain, but failed to do so. Is there any way to achieve this? Thanks in advance |
conjugate heat transfer, heat flow, heat flux, solid domain |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
[ICEM] Hybrid meshing in ICEM for 2D conjugate heat trnasfer | ishan_ae | ANSYS Meshing & Geometry | 7 | March 21, 2018 18:03 |
[ANSYS Meshing] Solid block inside a tunnel for smoke production (3D) | freddyflue | ANSYS Meshing & Geometry | 4 | December 15, 2017 16:39 |
heat conducting in a solid domain | Rogerio Fernandes Brito | FLUENT | 0 | March 18, 2008 17:25 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 12, 2001 23:19 |
