Need help for a centrifugal blower simulation |
September 7, 2022, 02:53 |
Thomas
I am having trouble getting good result on a fluent simulation. First of all, I am a begginer on ansys, I did have some lectures but it was more a "reproduce what I do" than a real teaching class. What I am trying to achieve : I am trying to make an FEA model to compare different fan and later volute design for a centrifugal blower. The design for now is created using solidworks but I have plan on trying to use VISTA to generate blade and volute designs later. The centrifugal blower opperates at room temperature and at atmospheric pressure. My atmosperic pressure, I mean that the air surrounding the fan is at atmospheric pressure. I want to set the RPM at which operates the fan, and obtain the air velocity at the outlet. What have I done : To validate my FEA model, I bought a centrifugal blower and got the step file from the manufacturer. 1) I have measured the real airspeed (arround 30m/s at the outlet) 2) From the step file, I have modeled the air inside the fan, and created a boolean substraction of the fan to get only one solid being the "mass of air" 3) I have imported this solid into ansys and made this named selection : inlet, fan, wall, outlet. 4) I have generated a mesh using edge sizing to locally refine the mesh and applied a tetrahedron mesh method. 5) I moved on to fluent, and set it like so : Energy on, K epsilon (I left it by default) 6) boundary condition : pressure inlet : everything by default pressure outlet : everything by default fan : fame motion, rotational motion (with the right axis coordinates), and the rotationnal speed of 3000 rpm by doing so, the outlet air velocity computed form ansys is arround 2-3 m/s. I beleive I am doing a lot of stuff wrong but I don't know where to start. thanks in advance, if you prefer screenshots of my settings please ask me. |
Modeling Centrifugal fan (blower)! Need Help! | namshaheb | FloEFD, FloWorks & FloTHERM | 2 | December 30, 2020 10:54 |
CFD of centrifugal blower | PVG | FLUENT | 0 | November 7, 2019 02:20 |
root blower simulation | carno | FLUENT | 4 | May 21, 2015 17:47 |
3D centrifugal compressor simulation | nuimlabib | Main CFD Forum | 0 | April 2, 2010 22:08 |
Doing Centrifugal Compressor Simulation? | Lee | FLUENT | 3 | March 31, 2010 05:28 |
