Modelling microchannel - inlet boundary condition
Old   September 3, 2022, 05:47
Default Modelling microchannel - inlet boundary condition
Delika Weragoda
DWera is on a distinguished road
How would you define the inlet boundary condition in a vertically oriented microchannel? I've seen many use either a constant velocity or mass flow rate but not a pressure BC. Can't it be defined as a pressure inlet BC, cause I'm trying to determine the velocity of capillary rise? (This probably might be more of a theory question than Fluent)
Trying to wrap my head around this, but looks like I'm not getting anywhere. Any help would be much appreciated.
DWera is offline   Reply With Quote
Old   September 6, 2022, 15:38
HHOS is on a distinguished road
You can set a pressure inlet or a pressure outlet with backflow Water or the fluid that is supposed to be sucked in by capillarity. Might be that you need to patch a little bit of liquid so that it starts "sucking" it in.
Regards
HHOS is offline   Reply With Quote
boundary conditions, capillary rise, inlet, micro channel, velocity
How to use movingWallVelocity boundary condition in velocity inlet? venturi123 OpenFOAM 0 December 6, 2020 04:29
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Pressure Inlet Boundary Condition Issue zoeburton1987 FLUENT 0 May 15, 2012 10:20
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
