How to implement hydrogen combustion?
Old   August 31, 2022, 18:06
Default How to implement hydrogen combustion?
Lucas Pelizzari
lpelizzari is on a distinguished road
I just want a BC injecting Hydrogen (H2) and have it combust with air (0.78N2 + 0.22O2) inside the domain, and the output should be N2, O2 and H2O, simple as that. There's no ignition, hopefully the air temperature (>1000K) should take care of that.
The Fluent tutorial (https://www.afs.enea.it/project/nept...ug/node537.htm) has proven unfruitful so far. It behaves like I'm just injecting more air into the domain.
Should I use the premixed or non-premixed model? It seems to be non-premixed, because, intuitively, premixed sounds like what you would have in a reciprocating engine.
What else can I do?
lpelizzari is offline   Reply With Quote
Old   August 31, 2022, 19:59
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
increase temperature locally in the beggining of simulation
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   August 31, 2022, 21:31
Lucas Pelizzari
How so? Can you be more specific?
Old   September 1, 2022, 04:35
Liu Wenchao
ChaoLW is on a distinguished road
You can patch high temperature (2000K) and high intermediates and product mass concentration in the initial filed.
In your case, the non-premixed model seems more accurate.
ChaoLW is offline   Reply With Quote
Old   September 6, 2022, 02:52
Alexander
press initialize, then PATCH option will be avaliable
best regards
combustion, fluent, hydrogen
How to simulate the LOX/GH2 spray combustion kanmaniraja FLUENT 0 June 25, 2018 12:17
Problem in Hydrogen combustion Rajshekhar Main CFD Forum 0 June 23, 2010 06:10
Multiresolution + Turbulence + Combustion Raul Phoenics 1 March 31, 2005 09:51
NOx Formation in Turbulent hydrogen combustion Ali Yigit FLUENT 1 December 22, 2003 04:50
Hydrogen combustion with swirl of coaxial air Harikishan FLUENT 0 December 18, 2002 08:46
