Import Viscous drag from Fluent to Static Structural
Old   August 27, 2022, 16:23
Default Import Viscous drag from Fluent to Static Structural
Karan Jha
karanjha is on a distinguished road
I am using Ansys FSI simulation between an object in fluid flow with one-way coupling. When I try to import the forces, I can only import the pressure distribution from Fluent to Static Structural in Ansys. I wanted to know if there is a way to import the Viscous forces, or is it that the pressure forces that I import somehow account for the viscous forces as well.
Thank You
karanjha is offline   Reply With Quote
drag analysis, fsi, viscous forces
Ishii-Zuber drag in Fluent CeesH Fluent UDF and Scheme Programming 7 March 16, 2017 10:52
pressure viscous drag on pipe Hossam Alaa FLUENT 0 December 30, 2014 14:50
FSI Fluent -> static structural zytra ANSYS 4 October 16, 2014 18:01
enum MASOUD Fluent UDF and Scheme Programming 0 June 5, 2010 01:49
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
