Error at host: Error code: 126
Old   August 25, 2022, 15:23
Default Error at host: Error code: 126
Liu Wenchao
ChaoLW is on a distinguished road
Hi, everyone! I am working on udf in Fluent recently. Ansys fluent 2021r2, vs 2019 professional.
I faced this "Error at host: Error code:126" problem while loading the libudf.
Does anyone have any clue how to solve this problem?
I deleted the folder "libudf" and recompile it, it doesnt works.
Thanks a lot.
ChaoLW is offline   Reply With Quote
Old   August 26, 2022, 03:15
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
udf was compiled in other fluent version
you should compile it again,even though you say its not a solution -> you didn't recompile probably
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   August 26, 2022, 05:44
Liu Wenchao
Thanks for your reply!
Here is the message from Ansys Fluent:
Microsoft (R) C/C++ Optimizing Compiler Version 19.28.29336 for x64
Copyright (C) Microsoft Corporation. All rights reserved.
udf_names.c
# Linking libudf.dll because of makefile user_nt.udf udf_names.obj edc-scale.obj
link /Libpath:"D:\Program Files\ANSYS Inc\v212\fluent"\fluent21.2.0\win64\2ddp_node /Libpath:"D:\Program Files\ANSYS Inc\v212\fluent"\fluent21.2.0\multiport\win64\mpi\ shared /dll /out:libudf.dll udf_names.obj edc-scale.obj mport.lib fl_mpi2120.lib
Microsoft (R) Incremental Linker Version 14.28.29336.0
Creating library libudf.lib and object libudf.exp
Done.
DESKTOP-6CP1L1E: Opening library "D:\P.Marge et al\ukomega\Frolov4.edc.2016\libudf"...
Error: Error code: 126\n
Error Object: #f
I also attach the .c file below.
Is there something wrong with the compilation?
File Type: c edc-scale.c (447 Bytes, 3 views)
Old   August 26, 2022, 15:30
Liu Wenchao
Problem solved.
It's hard to know why. But I uninstall the 2021r2 and install 2019 version. UDF is successfully loaded.
Calculating source term total cell-zone volume parallel computation RobV Fluent UDF and Scheme Programming 2 May 30, 2022 04:46
Host Node Allocation (-ssh and -cx) on Linux HPC bloodflow FLUENT 3 October 10, 2019 11:46
CFX parallel computing questions w784370882 CFX 3 January 1, 2019 01:40
Problem to run simpleFoam using qsub? be_inspired OpenFOAM 1 December 22, 2015 13:53
[OpenFOAM] Color display problem to view OpenFOAM results. Sargam05 ParaView 16 May 11, 2013 01:10
