Perforated plate with flow deflectors
Old   August 22, 2022, 19:36
Smile Perforated plate with flow deflectors
Gregori
greg93 is on a distinguished road
Dear all,
I'm trying to simulate a dryer that has a perforated plate fitted into it to distribute the air flow. The thing is that, each hole of this plate has a flow deflector. So the air flow in perpendicular to one face of the plate, and in the other face the flow is majoritary tangential (the dryer is cilyndrical).
I'm doing an extensive research in the literature but couldn't find the better way to model this. Constructing the geometry including the holes is unfeasible (about 10800 holes). I'm searching a way to use the porous media approach but the main problem here is that the flow direction after the plate it's not perpendicular to the plate's plan due to these deflectors.
Have you ever faced something like this or have any idea of the best approach?
Thank you guys for reading this!!!
greg93 is offline   Reply With Quote
angular, dry bed, perforated plate, perforated sheet, porous media
Drag Force Ratio for Flat Plate Rob Wilk Main CFD Forum 40 May 10, 2020 05:47
Finding Drag Force from Skin Friction Rob Wilk Main CFD Forum 0 May 8, 2020 07:04
Perforated plate as an inlet/outlet JulienV CFX 11 August 27, 2015 03:32
Setting up a case for a plane plate in a longitudinal flow Chronique OpenFOAM Running, Solving & CFD 0 October 9, 2014 15:17
flow in perforated pipe distributor pertupd ANSYS 0 August 12, 2009 09:36
