August 15, 2022, 15:23 |
udf for mass flux
Rep Power: 4 |
Hi all,
I am pretty new to the udf. I am trying to write a udf to set the diffusive flux equal to negative convective flux such that the total flux at the wall will be 0. (diffusive flux = - convective flux; diffusive flux + convective flux =0) Inlet has a mixture of two fluids. By writing this udf, only one fluid can travel through the wall. I am not sure where to start and what I should use. There are two options: DEFINE_PROFILE, DEFINE_UDS_FLUX. Let me know if there is a better way to approach this. Thank you. |
UDF for heat flux at membrane in membrane distillation process | yacarioca | FLUENT | 0 | March 9, 2021 23:58 |
UDF for reading radiative heat flux | ssa_cfd | Fluent UDF and Scheme Programming | 1 | December 14, 2020 00:53 |
uds flux - drift velocity - udf | johnwinter | Fluent UDF and Scheme Programming | 3 | November 25, 2017 04:07 |
UDF for UDS flux | gyf135 | Fluent UDF and Scheme Programming | 0 | October 13, 2015 20:02 |
UDF Mass flux computing | Carlo | FLUENT | 6 | November 23, 2014 21:59 |
