How to make gears mesh in fluent, so they rotate accordingly |
August 11, 2022, 03:08 |
Mahima Pareek
Rep Power: 4 |
I'm trying to study lubricant flow in Ansys fluent in relatively complex geometry. There are 3 gears. One of the gears is in mesh with the other 2 gears. And the rest 2 are in mesh with this 1 gear. I need to know how to define this gear mesh in Ansys fluent, so I just need to enter the RPM of the first gear and the other 2 rotate accordingly. What should I do in the setup of this system?
I am new to Ansys fluent and CFD, so really sorry if this is a silly or basic question. TIA |
cfd analysis, fluent, gears |
Transfer of mesh from Meshing to Fluent destroys the mesh | balrog_f | FLUENT | 9 | July 28, 2018 10:02 |
[ICEM] Error reading 2D hybrid ICEM mesh into Fluent | Kloz | ANSYS Meshing & Geometry | 1 | June 6, 2016 13:45 |
Lift and Drag pattern change wit FLUENT 16 and 13 PISO for same mesh n solver setting | arunraj | FLUENT | 0 | June 2, 2016 22:58 |
Export 2D mesh from ICEM to Fluent | BuilttoSpill | ANSYS Meshing & Geometry | 4 | August 28, 2010 08:16 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
