Simulation results of cfx and fluent are different. |
August 10, 2022, 01:53 |
Junyeol
Rep Power: 4 |
Hello, I am a student majoring in solid mechanics simulation.
I am currently trying to study fluid dynamics simulation. I ran the same fluid simulation using fluent and cfx respectively. The inlet mass flow is 0.0007 kg/s and the outlet static pressure is 90 mmhg. It's a simple static simulation of a single S-shaped tube. Both set the fluid as water, which has the same viscosity. I don't know why the wall shear contours of the two simulations are so different. thanks for your help. Last edited by dhehdxhdaus; August 10, 2022 at 03:22. |
August 10, 2022, 02:20 |
Alexander
Rep Power: 34 |
as the difference about 0.2% check all settings. models you are using, bc, mat properties, so on
best regards ****************************** press LIKE if this message was helpful |
CFX vs. FLUENT | turbo | CFX | 4 | April 13, 2021 08:08 |
Different Results using CFX and Fluent | ka1 | FLUENT | 0 | August 15, 2018 05:49 |
Transfer Fluent Results to CFX | yanqoue | FLUENT | 0 | September 9, 2016 09:18 |
Different result in CFX and fluent for mass trans.? is segregated better? | ftab | CFX | 7 | September 27, 2012 07:57 |
CFX results as initial value for FLUENT 6.3 | mohammad | FLUENT | 1 | January 23, 2012 06:39 |
