Accessing net reaction rates of each species in DEFINE_ADJUST? |
August 8, 2022, 07:54 |
Rep Power: 6 |
Hi all, the title pretty much says it all: How do I access the value of the current reaction rate for a species in each cell within an ADJUST UDF? I don't want to change the value, just read it. Is there a way, for example, to access the pointer *rr like you can in other UDFs (DEFINE_NET_REACTION_RATE etc.)?
Thanks! Baum |
August 10, 2022, 00:58 |
Alexander
Rep Power: 34 |
Look for Ansys Fluent Customization manual -> DEFINE_DPM_INJECTION_INIT -> example
that could be useful to get cell and thread you probably need a loop over particles, could be done like this: Code:
Injection *I; Particle *p; I = Get_dpm_injections(); loop(p, I->p) { code }
best regards ****************************** press LIKE if this message was helpful |
August 11, 2022, 03:23 |
Rep Power: 6 |
Hi Alexander, thanks for the reply. I looked at the UDF manual and could not really find anything about accessing the reaction rate there. It seems like they calculate their own reaction rate based on temperature and concentration, but they don't access the current value stored in the cell.
Also, I don't really want to use a DPM injection just to find this value, so I think an ADJUST UDF is definitely preferred. Maybe another way to formulate this question could be: Can I just write "Reaction Rate *rr" or something similar somewhere in the ADJUST UDF and access that structure? |
Which macro gives the net reaction rate of species in a multistep chemical reaction | Van9527 | Fluent UDF and Scheme Programming | 0 | March 12, 2021 03:36 |
Reaction Species transport and Population Balance | abgoel363 | Fluent Multiphase | 0 | January 20, 2020 07:08 |
Modelling species transport and implementing reaction rates | res | FLUENT | 0 | May 11, 2017 10:29 |
Segmentation fault in running alternateSteadyReactingFoam,why? | NewKid | OpenFOAM | 18 | January 20, 2011 16:55 |
chemical reaction - decompostition | La S. Hyuck | CFX | 1 | May 23, 2001 00:07 |
