Possibility of accessing data from previous timestep for use in an expression |
August 5, 2022, 18:35 |
Paul
Hello all,
I'm currently working on a system that has an mass flow inlet boundary condition that I want to vary over time based on the pressure at the inlet during the last timestep. I'm using expressions in fluent in order to do this and setting and trying to set an expression for the mass flow rate that is based on the inlet pressure at the last timestep. I've figured out how to do everything except for getting the average pressure data across the surface from the previous timestep. How would I go about doing this? |
expression editor |
Error reading profile data in expression in cfx post | banu | CFX | 4 | March 27, 2015 09:03 |
studying a valve case | mina.basta | OpenFOAM | 33 | August 30, 2013 04:46 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
Accessing Variables from Previous Timestep | Vinayak Barve | FLUENT | 1 | March 10, 2004 07:40 |
Loading data from previous simulations. | Ale | FLUENT | 2 | September 9, 2003 12:12 |
