Measuring incident thermal radiation from a flame by creating a virtual radiometer
Old   August 2, 2022, 09:46
Default Measuring incident thermal radiation from a flame by creating a virtual radiometer
Jane
DomBadger is on a distinguished road
Hello, I simulated a turbulent diffusion flame and now trying to calculate the incident thermal radiation to several remote radiometers (targets) around the flame at various distances. The radiometers have a hemisphere view, which means they have a facing direction and are only receiving thermal radiation coming towards them.
But the "incident radiation" variable in Fluent seems not the right one to use here. When I created a bounded surface/plane by giving the coordinates of 3 points, and used the variable "Integral--radiation--incident radiation" to get the incident thermal radiation on the surface, the values were clearly off.
What's more, I found that the bounded surface created indeed has a normal direction, because the mass flow rate through it would adopt opposite signs if I switch the order of the 3 points used to create the surface (either clockwise or counterclockwise). However, even surfaces with the opposite normal direction would lead to the exact same value of "Integral--radiation--incident radiation".
Already read this thread Measuring Radiaiton from a Flame but the question is not solved.
I wonder how to create a surface only facing one side and is a wall on its back. Or any of your experience in obtaining a reasonable incident thermal radiation value.
DomBadger is offline   Reply With Quote
bounded plane, incident radiation, non-premixed combustion, radiation field, radiation flux
Surface integrals report: incident radiation Novice FLUENT 3 February 8, 2018 10:53
Fluent Radiation/porous media Schmitt pierre-Louis FLUENT 26 September 1, 2016 11:29
Modeling both radiation and convection on surfaces - Ansys Transient Thermal R13 s.mishra ANSYS 0 March 31, 2012 05:12
Incident Radiation Nicki CFX 1 April 17, 2009 09:18
Info: Short Course On Thermal Design of Electronic Equipment Arnold Free Main CFD Forum 0 August 10, 1999 11:18
