July 28, 2022, 03:12 |
filter layer in a water channel
Vahid
Rep Power: 5 |
Dear Ansys user,
I am trying to simulate a line in a water channel (model 2D), which should be able to filter some particles from the flow. the aim is to simulate a line with resistance again some particles (2nd phase). but I don't know how can I do it, any suggestion? I know that defining a porous area would be possible. but I want to know, are in Ansys any possibilities to define a specific resistance for the filter? how it should be? should I define a user-defined (UDF) boundary condition for example? geometry: 2D simple flow channel. inlet outlet and top and bottom as wall, in the middle, a line as the filter. any help would be appreciated Regards |
filter layer, porous boundary |
[snappyHexMesh] No generation of layer onto zerothickness surface | crubio.abujas | OpenFOAM Meshing & Mesh Conversion | 3 | October 25, 2022 03:20 |
[snappyHexMesh] Optimizing snappyHexMesh for internal (ribbed) channel flow | backscatter | OpenFOAM Meshing & Mesh Conversion | 1 | November 5, 2018 13:28 |
[ICEM] tidal turbine meshing in ICEM inside a water channel | eeLio | ANSYS Meshing & Geometry | 0 | January 11, 2018 09:53 |
[snappyHexMesh] Adding layer 3d wing (y+=1) | Dorian1504 | OpenFOAM Meshing & Mesh Conversion | 4 | November 10, 2017 00:56 |
[snappyHexMesh] Boundary layer generation problems | ivan_cozza | OpenFOAM Meshing & Mesh Conversion | 0 | October 6, 2010 13:47 |
