Floating point exception error on a pipe flow |
July 19, 2022, 10:40 |
Rep Power: 7 |
I'm trying to simulate a compressible subsonic air flow through a pipe with a pressure inlet and mass flow outlet. Pipe flows into a container which I removed and added a partial sphere. Viscous model is realizable k-e with enhanced wall fn). Mesh has skewness bellow 0,97, min orth quality is 0,02.
When I run the simulation, it gives a floating point exception error after about 200 iterations. When I did the simulation without the partial sphere everything went smoothly. I have no idea what is the problem. Model screenshot: Image link: https://imgur.com/tVGrdzG |
July 26, 2022, 04:28 |
Rep Power: 4 |
when with partial sphere, this case may possibly not a steady flow. You may try the use the transient to simulation it
July 26, 2022, 06:37 |
Rep Power: 7 |
If I understand correctly, the problem is the shape of the sphere itself? Should I change it to a cuboid then?
July 27, 2022, 01:19 |
Alexander
Rep Power: 34 |
I think the problem is not the shape but the flow, which could be complicated because of shpere shape. It could oscillate thats why transient simulation was suggested
best regards ****************************** press LIKE if this message was helpful |
July 27, 2022, 02:43 |
Rep Power: 4 |
When the flow pass through the barrier, it may cause the unsteady flow. such as the karman vortex.
July 27, 2022, 04:13 |
Rep Power: 7 |
What I meant was, how does the shape of the outlet (in my case sphere) impact the divergence or as you described it, oscilation?
Update: I ran another simulation with a cuboid outlet shape and the case converged without any issues. My problem is now solved but I would like to understand how the sphere impacts the calculation. |
error floating point, fluent |
Floating point exception error when rotate the geometry | zyfsoton | OpenFOAM Running, Solving & CFD | 1 | June 20, 2022 06:49 |
icoFoam floating point exception (8) | leizhao512 | OpenFOAM Running, Solving & CFD | 7 | November 1, 2018 12:43 |
Cylindrical pipe - nonNewtonianIcofoam - Floating point exception (core dumped) | harshchandak97 | OpenFOAM | 0 | July 8, 2017 02:40 |
[snappyHexMesh] snappyHexMesh and cyclic boundaries | Ruli | OpenFOAM Meshing & Mesh Conversion | 2 | December 9, 2013 07:51 |
pimpleDyMFoam constantly giving floating point exception and solution divergence | fedvasu | OpenFOAM Running, Solving & CFD | 0 | November 28, 2013 01:53 |
